2CarPros - Car Questions & Answers
1999 Ford Contour Repair Question
Topics covered: Spark, Engine, Coil pack.
Asked on June 10, 2010
1999 Ford Contour won't run.
Engine Performance problem
1999 Ford Contour 6 cyl Front Wheel Drive Automatic
The car started running rough. Then after we got home it wouldn't start. We didn't have the money to fix it so it set for a little while. Then it started and ran for quite a while. After it sits for a while it will start and run. Then when it dies it won't run again for awhile.
Avatar Asked by sjwest1964
Answer
Replied on June 10, 2010
Let's do below for a start to determine whether it's a fuel or spark problem-and get back with some result.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tiny Answered by rasmataz
68 questions asked
