Mechanics
FORD CONTOUR ENGINE PROBLEM
1999 Ford Contour
Engine Mechanical problem
1999 Ford Contour 4 cyl Two Wheel Drive Automatic 192200 miles
Hello, I have a 99 contour and I want to replace the timing belt. Where are located the timing marks, Thank you
Argelio01
January 27, 2009.
Check the link below it has all the marks you need
http://www.2carpros.com/car_repair_information/tec_info/1999/ford/contour/1999_ford_contour_timing_belt_diagram_marks.htm
also required to have a special tool
http://www.2carpros.com/forum/automotive_pictures/99387_Untitled1_4.jpg
BMRFIXIT
Jan 27, 2009.
