Mechanics
FUSE REPLACEMENT
1998 Ford Contour
Electrical problem
1998 Ford Contour 6 cyl Front Wheel Drive Automatic 100000 miles
How do you remove the ABS/fan motor fuse from the fuse bloc? It is a 60 amp fuse. It does not look like the standard plug-in fuses and seems impossible to remove.
John Welker
January 14, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
