1996 Ford Bronco Repair Question
Topics covered: Axle, Transfer case, Differential.
Asked on January 11, 2010
1996 Ford Bronco 4x4
Drive Train Axles Bearings problem
1996 Ford Bronco V8 Four Wheel Drive Automatic 135000 miles
I have taken this to my mechanic. The little motors behind the transfer case turn on and I hear a noise on the passenger side but it doesn't seem like the front tires want to pull when I engage the 4x4. What could this be? Bad hubs, they are automatic.
Answer
Replied on January 12, 2010
If you are sure the 4wd actuator on the transfer case is working, then either the hubs are bad or there is a vacuum problem to the front differential / axle. If the hubs are bad, they will usually make a grinding sound when they slip. If you hear nothing, then check to make sure there is vacuum to the front axle. If the axle doesn't engage, it doesn't matter what the transfer case does. It won't work.
Replied on January 13, 2010
The only line I found on the front diff was the over flow line.while I was under there I turned the front drive shaft and the left axle turned but not the right. Do I just need to take it to another mech?
