1990 Ford Bronco Stalling
1990 FORD BRONCO
129,000 MILES • V8 • 4WD • AUTOMATIC
UZI308
My Bronco after it warms up stalls when the vehicle is put into gear. You can drive it if you keep the RPM's up when stopping. Otherwise it stalls. Have changed the fuel filter, checked plugs and wiring.
Thanks for any assistance.
Mar 20, 2008 at 1:19 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Sounds like the IAC (idle air control) valve may be bad. Try cleaning it out with carb cleaner and also clean out around the butterfly in the throttle bore with carb cleaner and a rag
Mar 20, 2008 at 5:33 PM
