1988 Ford Bronco Repair Question
Topics covered: Clutch, Planetary gear, Transmission.
Asked on January 17, 2010
1988 Ford Bronco Transmission issues
Transmission problem
1988 Ford Bronco 6 cyl Two Wheel Drive Automatic
Trans lost power and fluid, I took it apart and found the front planetary gear under the clutches all the springs were shattered, I went to the junk yard purchased another. I replaced the front seal, then put back together and installed trany to motor. filled with fluid, started, moved selector back and forth to get fluid into convertor. added more fluid, Idled motor, fluid then leaked out of breather. While moving selector their was no motion change in trany.
