Mechanics
ALWAYS RUNNING HOT
1996 Ford Aerostar
Engine Cooling problem
1996 Ford Aerostar 6 cyl Two Wheel Drive Automatic 140000 miles
I have fixed a minor coolant leak and replaced the fan clutch, thermostat and the water pump yet the van is still running hot or appears to be. Any suggestions would be appreciated.
Meekcentral
July 31, 2009.
If the radiator is not clogged could be airlock in the system try bleeding it -don't work time to get it block and pressure tested.
Rasmataz
Jul 31, 2009.
AD
