1988 Ford Aerostar Repair Question
Asked on September 12, 2009
1988 Ford Aerostar fuel pump
Electrical problem
1988 Ford Aerostar
with the ignition in the run position, what should the voltage be at the pump? I'm getting 6 volts at the plug connected to the fuel pump assembly.
1988 Ford Aerostar
Answer
Replied on September 14, 2009
It is a 12 volt pump. Check voltage at the relay. Let me know what you find.
