Mechanics
ENGINE SHUTS OFF WHILE DRIVEING
2001 Dodge Ram • 180,988 miles
My engine will shut off while driving must of the time when it gets hot outside I get a engine light when I try to start it the engine light goes out and I don't get it again I have a CARMD TESTER which I see if I get a code even though I don't have a engine light it shows no code it will show either a green yellow or red light and the light is yellow giving me a report of my emenison system somes time my truck won't start back right away I hafto let it set for awhile a friend of mine said it might be my EGR valve but I don't have one on my truck I cant find any vacuum leaks I put a battery I change the fuel pump 6 month ago can you help me
Metal2
May 17, 2013.
Codes are identified by specific code numbers and that's what we need to know. You may need a different scan tool.
Wrenchtech
May 17, 2013.
