Mechanics
ENGINE LOST SPARK FROM COIL TO DISTRIBUTOR. HAVE 12V AT PRIMARY COIL TERMINALS, NO SPARK, CRANKS BUT WILL NOT START.
1995 Ford F-150 • 118,000 miles
Engine was running perfectly, stalled while driving, won't restart. No spark from distributor to plugs. Checked cap, rotor, and wires - OK. 12V present at coil primary terminals, but no output to distributor. Removed and checked coil with VOM. Found 8K ohms resistance from both primary terminals to secondary terminal. 0 ohms (full continuity) across primary terminals. Detected slight burning smell in interior under drivers side of dash. Checked area, found nothing.
Pat Simkins
November 2, 2013.
Which engine?
Mhpautos
Nov 3, 2013.
AD
