Here is a list of things I have tried over the last year or so:
1. Replaced the spark plugs
2. Replaced the front and rear ignition coils
3. Used high quality fuel-injection cleaner
4. Replaced air filter
5. Replaced Fuel Filter
6. Cleaned the MAF sensor
7. The fuel pump is only about 12-18 months old (though I'm not sure if the problem was before or after the new fuel pump.
For the most part, I have not had any check engine lights. I had some a few months ago, but they were due to a failing ignition coil. Last week, I got the check engine light, and after getting a free scan at the parts store, it revealed a whole slew of error codes:
p1811 - Maximum adapt and long shift
p0402 - Excessive EGR Flow
p0405 - EGR Position Sensor Low Voltage
p0171 - Fuel System Too Lean (Bank 1)
p0174 - Fuel System Too Lean (Bank 2)
p0051 - H02S Heater Control Circuit Low Bank 2 Sensor 1
p0152 - Oxygen Sensor Circuit High Voltage (Bank 2, Sensor 1)
p0300 - Cylinder Misfire Detected – Random Cylinders
p0303 - Cylinder #3 Misfire Detected
After receiving these codes, I have replaced the rear ignition coil, the air filter, and cleaned the MAF sensor. After doing this, the check engine light went off. I think this may have resolved the P0300 and P0303 because the front ignition coil failed not long ago. However, yesterday, the check engine light came back on. This time, the ODB scanner only revealed 1 error code. This code was a P0050 (H02S Heater Control Circuit Bank 2 Sensor 1). After doing a little research, we thought it may have been a faulty Oxygen sensor. I believe this car has 2-3 sensors, so I tried to determine which one I thought may be the problem. After a little research, I believe the bank 2 sensor 1 was the oxygen sensor near the front of the engine (cylinders 2, 4, 6) near the exhaust manifold. We replaced that today, but the problem persists. The car drives fine at highways speeds. In fact, sometimes the car accelerates smoothly. The problem seems to come and go quite regularly.
I have tried to be very thorough in explaining the problem. Please let me know if you can help. I am hoping to fix the problem myself without spending too much money, if possible. Thank you!
SPONSORED LINKS
have the same problem?
Monday, July 15th, 2013 AT 3:29 PM
