engine cutting out
2003 FORD FAIRMONT
180,000 MILES • 4.0L • 6 CYL
MIRACLE1
Random problem engine just cuts out then no crank for few minutes. IV replaced steering column ignition , crank and cam sensors , throttle body , relays , plugs coils , done wiggle wire test , neutral safety switch , starter motor and I still can't find problem it just looses all power to engine completely cuts out and then no crank for sometimes 30srconds upto 3 minutes . When turn key no power to starter or fuel pump sometimes just changing from park to neutral.can get it to crank again but neutral switch is ok or some times taking key out and back in can get it to crank again sometimes just have to wait a little while then it will crank again and it will run like new untill next time it does it could be 5 min later could be 2 days later. Thanks for your help it's driving me insane I don't have money for a mechanic no codes also but will throw a random code that has nothing to do with problem
Sep 16, 2019 at 5:50 AM
