Engine shut off while driving?
SWIP3R
  • 2006 DODGE CHARGER
  • 2.7L
  • V6
  • 200,000 MILES
I was driving 60 MPH plus, and my car started losing power and would not shift gears. I slowed to the side and the car cut off. I jumped it and it cranked back up roughly and shit down again and never cranked again. I replaced crank and camshaft sensors. My belts turn. I hear the fuel pump turn on. Starter good. Only code I am getting is U1120. U1120-Lost wheel distance message.
Set Condition:
The PCM does not receive a wheel distance message from the Anti-lock brake Module or FCM (NON-ABS) over the CAN C bus. Is this stopping it from cranking? Did not get this code until I got it towed home. Please help! Was in a accident two months before. Sat the shop for a month getting fixed. A hose from my air filter was off when I got it back. Put it back on and never had a problem until now.
Sunday, December 2nd, 2018 AT 4:30 PM
  • 108,133 POSTS
If it will not start, I doubt the brake code is preventing it from starting. First, you need to make sure you are getting spark and fuel to the engine. Take a look through this link:
Keep this in mind. Just because the fuel pump is running does not mean it is producing enough pressure to run the engine. Here are specific links for checking spark and fuel:
Here are the specs for fuel pressure:
Fuel System Pressure
400 kpa ±34 kpa (58 psi ± 5 psi)
Let me know if any of this helps or if you have other questions.
Saturday, August 15th, 2020 AT 10:19 AM
SWIP3R
  • 12 POSTS
Okay, I am going to take a look at it. I smell gas when I am trying to crank it. I also changed the throttle body I forgot to say.
SWIP3R
  • 12 POSTS
I just check all my fuses and relays. Still nothing. I tried to crank it once it just clicked. I turn the key off and did it again and it tried to crank actually sounded better but did not start. I also do not have a fuel pressure gauge, so I am asking around to some of my mobile mechanics. Just found out I got two fuel pumps and I only hear one come on so probably is my problem.
  • 108,133 POSTS
Hi and welcome back:
Honestly, there is one pump. It is located in the fuel tank. As far as hearing it run, it may but be producing enough pressure or any at all.
I am not sure where you are located, but most parts stores will lend or rent you a fuel pressure gauge.
When you try to start it, do you get one click and then nothing? If so, make sure the battery terminals are clean and tight.
Also, make sure the battery is good, You may want it load tested at a parts store to confirm.
SWIP3R
  • 12 POSTS
My driver side fuel pump was not coming on. I changed my fuel pump today, looked pretty dirty. Now my battery keeps dying before I can see if it will crank. My car been sitting for awhile now since I been getting it worked on and I have gotten it recharged like five times now. Getting it checked first to make sure it needs charging and it does. So hopefully it will crank up once I let it charge for awhile at the auto store. I made sure everything is off so I am not sure what is draining it so quick. I will respond again before the night is over. Thanks
  • 108,133 POSTS
Welcome back.
If you feel something is draining the battery, take a look through this link:
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know if it helps.
SWIP3R
  • 12 POSTS
So I got everything charged and hooked up. It still turns over without enough speed to crank. Pretty sluggish. Now when I attempt to crank all lights work on the dash. But no noise it just beeps when I let go of the key after trying to crank. I do not see any security lights. Just traction and ESP and I get the same check engine code U1120. No clicking from the starter. But it still could maybe be the starter. Before it broke down it took awhile to turn over before it caught sometimes.
  • 108,133 POSTS
Welcome back.
Based on your last post, we need to check the starter to determine if it is bad or there is another issue. Follow this link:
Let me know what happens.
SWIP3R
  • 12 POSTS
Still nothing when I turn the key. Only hear the fuel pump come on. Check engine light blinks. My battery shows for a quick second and goes away. But I still have a lighting bolt that stays for awhile before it goes away. A friend of mine had the same problem and it turned out to be his accelerator sensor. Or pedal sensor I think it is called. Is it a way to tell if it is before buying a new one?
  • 108,133 POSTS
Hi and welcome back.
The lightening bolt indicates an issue with the throttle position components. It really needs to be scanned to determine where the problem is coming from.
Here is a quick video that shows how it is done:
https://youtu.be/b2IJGfImVvw
I realize most people don't own a scanner, but often times parts stores will lend or rent one to you. That is really needs done at this point. Otherwise, it becomes a guessing game.
SWIP3R
  • 12 POSTS
I have recently brought one and I’ve scanned it multiple times and only get the same code but it says it’s two codes. This is word for word what the scanner says:
2 codes
U1120
U1120
Mil on
Monitors
5inc
Catylyst Evap o2 sensors
02 htr
EGR
3 ready missfire fuel comp
SWIP3R
  • 12 POSTS
  • 108,133 POSTS
The code, U1120 means the abs module has lost communication with speed sensors You need a live data scanner to determine if one of the abs sensors has failed or all. If the module is bad, it won't communicate with the scanner. However, I don't feel that is why it won't start.
Are you certain you are getting spark and fuel to the engine? The things you listed indicate a few different things. It indicates several of the modules in the vehicle have not yet completed a cycle to know if they are working. Most likely, it is the result of either having the battery disconnected or if the codes were erased with a scanner.
SWIP3R
  • 12 POSTS
I just brought a new battery. So yes the battery has been disconnected. And I don’t have anyway to check and see if gas is getting to the head again. I’ll have to rent a gauge again.
  • 108,133 POSTS
An easy way to check for fuel is using starting fluid. If the engine starts for a couple seconds using starting fluid, and then stalls, that would indicate there is spark to the plugs, but there is no fuel getting to the engine. It's quick and easy.
SWIP3R
  • 12 POSTS
Once again it doesn’t turn over so it’s no possible way for me to check that way.
  • 108,133 POSTS
Okay,
I just read through every post. It did crank in one, but it was slow. Now, I watched the video and saw what is happening. Reconfirm that the starter relay is good. Switch it with a different relay in the power distribution box that has the same part number.
If that doesn't change anything, I need you to check the starter. In the first link you indicated it was good then mentioned it may be bad because you had problems prior. So, I'm a bit confused. Try the test in this link:
Now, you will need a helper to check that. Have the helper turn the key to the start position while you check for power to the smaller wire. If there is power, disconnect the battery and remove the starter and have it bench tested at a parts store. It most likely is bad.
Next, if there is no power to the smaller wire, we need to start at the power distribution box to see if power is available to the starter relay and then trace one way or the other to determine where power is being lost.
One last thought, make sure the ground between the battery and the engine block is in good condition as well as the power to the starter. However, since the starter was taking time to work or turning slower than it should prior to the problem, I feel that may be the problem.
Let me know what you find,.
SWIP3R
  • 12 POSTS
I checked the starter and it turns over when I manually check it but it still doesn’t start. I changed my ignition switch and my pin inside was still well intact. When I turn the key still nothing doesn’t crank either.
  • 108,133 POSTS
From here, the only thing I suggest is checking the starter relay, ignition output fuse. Here are the directions:
______________________________________
STARTER RELAY
Warning: check to ensure that the transmission is in the park/neutral position with the parking brake applied. This may result in personal injury or death.
RELAY TEST
The starter relay is located in the Power Distribution Center (PDC) in the engine compartment. Refer to the PDC label for relay identification and location.
Remove the starter relay from the PDC as described to perform the following tests:
1. A relay in the de-energized position should have continuity between terminals 87A and 30, and no continuity between terminals 87 and 30. If okay, go to Step 2. If not okay, replace the faulty relay.
2. Resistance between terminals 85 and 86 (electromagnet) should be 75 ±5 ohms. If okay, go to Step 3. If not okay, replace the faulty relay.
3. Connect a battery B+ lead to terminals 85 and a ground lead to terminal 86 to energize the relay. The relay should click. Also test for continuity between terminals 30 and 87, and no continuity between terminals 87A and 30. If okay, refer to Relay Circuit Test procedure. See: Starting System > Component Tests and General Diagnostics > Relay Circuit Test. If not okay, replace the faulty relay.
Let me know what you find.
SWIP3R
  • 12 POSTS
Timing chain. It’s in the shop now being fixed.
