1993 Eagle Vision Repair Question
Asked on February 11, 2010
1993 Eagle Vision
Engine Mechanical problem
1993 Eagle Vision 6 cyl Front Wheel Drive Automatic 193203 miles
What does it mean when black water comes out of the tailpipe, and also if only four of my six cylinders are firing?
Answer
Replied on February 15, 2010
Water is condensation in the exhaust and is normal. The black stuff is carbon from incomplete combustion of the fuel / air.
How do you know two cylinders are misfiring? Two paired cylinders misfiring could likely be caused by one defective ignition coil in the coil pack. GM puts a lot of electronics in their coil packs, but Chrysler coils are relatively inexpensive. If a coil is shorted, the engine computer can shut that circuit down to prevent damage to the drivers in the computer. It is possible for the problem to be caused by the computer or wiring, but the coil is more common.
caradiodoc
