1997 Eagle Talon
Transmission problem
1997 Eagle Talon 4 cyl Front Wheel Drive Manual 135000 miles
I just recently had my slave cylinder replaced and not my car wont move. I have pressure in the clutch pedal. It is almost like my clutch is slipping, if I put the car in reverse and then rev the engine, at about 5500rpm my car will inch back. But I can put my car into first through fifth gear without my clutch pedal being pushed down. (While the car is running)Reverse does it too. I beleive it is maybe my pushrod on the slave cylinder is too long and wont let my clutch engage? Maybe a damaged master cylinder or clutch fork? Thanks in advance!
June 27, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
