1995 Eagle Talon Repair Question
Topics covered: Gas, Engine, Engine performance.
Asked on March 10, 2010
1995 Eagle Talon bogging
Engine Performance problem
1995 Eagle Talon 4 cyl Front Wheel Drive Manual 138, miles
when idling car is rough. like it is missing. i replace plugs and drive car does ok when taking off slow. then at about 1/2 throttle car wants to bog down, i let off gas a little to resume acceleration. then the car sems to be missing again afer a second of idling. if i idle and hit the gas car sputters a lil. but if i mash the gas gradually it runs fine. the faster i hit it the more it bogs. like its not running off a piston or something. i replaced tps. fuel filter about 3 months ago. and just put in new fuel pump. new computer. plugs again, coil seems ok. wires are ld but seem to be doing the job? i cleaned the iac valve. put in new ignition. i have cold air intake, headers and high flow cat. with cat back exaust. car ran good before.... have no clue and i cleaned the egr. it does not stick. also no cel. when i unplugg stuff the cel will come on. then i just reset it. the motor has been rebuilt about 4 weeks ago. car sometimes stalls and turn key and wont start. give it a minite then it will. also cuts of and on realy fast while driving. not so much now that i gave the bogging down problem. took car to shop and put on computer. could not get codes to pop up. no one realy knows what the problem is.
