1993 Eagle Talon Repair Question
Topics covered: Clutch, Shifter, All wheel drive.
Asked on August 8, 2010
1993 Eagle Talon low clutch
Transmission problem
1993 Eagle Talon 4 cyl All Wheel Drive Manual 255000 miles
I have a 93 eagle talon tsi with the 2.0L turbo. Ive owned this car for about 6 months now. ever since I got it it had a low clutch. It would grind into 3rd and reverse the worst. I replaced the clutch slave and master cyls, bled new brake fluid threw the system, replaced the clutch with OEM, shimmed out the fork, and adjusted the pedal as far as I could. and still no change! I put in a short shifter and it helped with the grinding for about a month. before I put the short shifter in I couldnt even get it in 3rd :S I can shift without the clutch, so I know my syncros are fine... ANY OTHER IDEAS???
