Mechanics
DOOR LOCK SWITCH UNLOCKS ONLY
1999 Ford Explorer • 173,000 miles
My doors will auto lock when the car starts, but does not unlock when I get out of car. (Not sure if mine is suppose to unlock that way or not). But if I turn off the ignition and get out I can't use the button to lock the doors the switch will work to unlock it. I can lock and unlock the doors with the key. Not sure what to do. The only fuse I found that is for locks is good.
AD
Liljinx
May 13, 2013.
The GEM module controls this function. You need a shop with a scan tool to see if this command is working
ASEMaster6371
May 13, 2013.
AD
