Mechanics
FLYWHEEL
2006 Dodge Truck
Transmission problem
2006 Dodge Truck V8 Two Wheel Drive Manual 51000 miles
this truck has flywheel like I never sen before how does the flywheel come off it has two parts to it how do you get the front part off to get to the flywheel bolts
AD
Dragracer36477
September 6, 2008.
CLUTCH -2006 Dodge Pickup R1500
Page 1 of 1
REMOVAL
Fig. 23: Pressure Plate Bolts
Courtesy of DAIMLERCHRYSLER CORP.
1.Remove transmission. 2.Loosen pressure plate bolts evenly, a few threads at a time and in a diagonal pattern to prevent warping the plate. 3.Remove bolts completely and remove pressure plate and disc. 4.Remove flywheel bolts and remove flywheel.
NOTE: Vehicles with Dual Mass Flywheel use an adapter plate between the flywheel and crank. This plate does not need to be removed.
9/6/2008 CLUTCH -2006 Dodge Pickup R1500
Page 1 of 1
FLYWHEEL-SRT10
DIAGNOSIS AND TESTING
FLYWHEEL-SRT10
Common causes of flywheel problems:
Incorrect bolt tightening Mounting the flywheel on a dirty crankshaft flange Improper seating on the crankshaft flange shoulder Heat warpage Loose flywheel to crankshaft bolts
The flywheel should be replaced if warped or overheated. Do not machine the face of the flywheel to correct a warped or overheated condition.
Clean the crankshaft flange and its mating surface on the flywheel before assembling. Dirt/grease in this area could cause the flywheel to mis-aligned when installing.
Use new bolts when mounting flywheel and secure the bolts with Moparâ„¢ Lock and Seal or equivalent. Tighten flywheel bolts to specified torque only. Over tightening can distort the flywheel causing run out.
REMOVAL
Fig. 25: Clutch Assembly
1.Remove transmission clutch housing and clutch assembly (2). 2.Remove flywheel (1) bolts and remove flywheel.
INSTALLATION
Fig. 26: Clutch Assembly
1.Clean flywheel bolts and apply thread sealer to bolts. 2.Install flywheel (1) on engine and install flywheel bolts. 3.Tighten flywheel bolts to 74 N.m (55 ft. lbs.). 4.Install clutch assembly (2), clutch housing and transmission.
9/6/2008
http://www.2carpros.com/forum/automotive_pictures/62217_ppa_1.jpg
http://www.2carpros.com/forum/automotive_pictures/62217_clutch_1.jpg
SRT10:
Merlin2021
Sep 6, 2008.
AD
