Mechanics
NEW REBUILT TRANNY, WONT COME OUT OF PARK
Dodge Stratus
1998 2 wheel drive Dodge Stratus 2.4 liter 16 valve duel over head cam with 4 speed a604 automatic transmission without abs approx. 100,000 miles
Just put in the rebuilt tranny and started it up and it wont come out of park, although it sounds like its shifting gears. Lights, fuses and switches are not the problem. Thinking although the car is level and has been the problem maybe the parking prawl is there any other possibilities that should be considered?
Thank you for your assistance
Mechjeff
September 17, 2007.
You said it sounds like its shifting gears
but wont come out of park
IM confused here
is it your level that you cant move out of park
or you put it in R or D and act like its in park
if its the level check brake light switch
plus you have over ride switch you can use to get it out
and try you’re new transmission!
But if you put it in drive and acts like its in park check if the lever cable connect the writ way to the transmission by the N/S switch put it in R see if you have back up light
BMRFIXIT
Sep 17, 2007.
