Power windows not working properly?
2006 DODGE STRATUS
170,000 MILES • 2.6L • V6 • 2WD • AUTOMATIC
JOHN MADEIRA
My front driver/passenger windows will not operate as well as the power lock button.The back windows work just fine.
Jul 4, 2019 at 8:06 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
Does the windows and door locks operate from the passengers side? If not it sounds like the main window switch has gone out. here is a guide to help you test to confirm the issue with diagrams and instructions below to show you how to replace the switch on your car:
https://www.2carpros.com/articles/electric-window-repair
Check out the diagrams (below). Please let us know what you find.
Jul 5, 2019 at 5:27 PM
VEREDIA
Electrical problem 4 cyl Two Wheel Drive Automatic 43000 miles
All fuses and relays have been tested with a tester, and are fine. The problem seems to be in the door where the swithes are. I don't know how to get the cover off to check for loose wire, or if this is even a possible problem. Please help. My driver side window is stuck halfway down, and it is supposed to rain this weekend. I have no garage. Also I am a single mother with no one to help. Garages are all closed on weekend in this small town.
Thanks,
Veredia
Aug 29, 2020 at 1:13 PM (Merged)
CARADIODOC
  • 34,309 POSTS
There is not much to do if you cant get it to move except tape a plastic bag over the window. Try to hold the switch in the "up" position while you pull the window up.
You can get the part on Amazon for 90.00 bucks
https://www.amazon.com/gp/product/B007CJ6IT4/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B007CJ6IT4&linkId=4df3d92054ba77502806498d1b013270
If the window starts to move, suspect a bad window motor. I have a fix.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Check out the diagrams (Below)
Cheers, Caradiodoc
VEREDIA
Thank you I will have time this weekend good thing I have prime.
QUINNBRIANA
Electrical problem
2005 Dodge Stratus 38,000 miles
I recently replaced the motor in my driver's side front window, but now all 4 of my power windows stopped working at once! What could be causing this? Could this be something as simple as a fuse, or does it sound like something more complicated/expensive?
ZACKMAN
  • 4,202 POSTS
If all four motors don't work, the culprit may be the relay. There are two places where it may reside. in the relay/fuse box under the hood or dashboard side panel on the driver side.
NEMEYERS
I just purchased this car used SXT model. Only the passenger front power window works. The fuse is good. There is no sounds from the window motors when you push the buttons. Is it possible three of the four window motors need replaced?
SCGRANTURISMO
  • 4,897 POSTS
This could be bad power window switches. I have included a wiring diagram of the Power Window Circuits in your vehicle in the diagrams down below for you. Please check for battery voltage at each one of the power window switches. I have included a link below for you to go to if you are unfamiliar with how to use a multimeter.
Please get back to us with what your voltage readings are, please. We can go from there.
Thanks,
Alex
2CarPros
TEALEX06
2003 dodge stratus window problem: My window wont roll up. It rolled down, but now won't go up. Is it the motor or the switch?
  • 110,190 POSTS
Have you checked if there is power to the motor? Also, check the wiring between the door and the door frame. The wiring in the rubber boot has a problem with breaking.
Let me know what you find.
JGBADILLO
The passengers window switches will not operate the windows at all. The master switch will operate them up and down with ease.
The master switch will not lock or open any of the doors. The only one that works some what is the front passenger side, it only locks all the doors but will not open them.
I checked the fusses and did not find any that where bad.
Aug 29, 2020 at 1:14 PM (Merged)
CARADIODOC
  • 34,309 POSTS
For this type of problem, start by checking for broken or frayed wires between the door hinges. If you find any, I'll paste a copy of how I repair them.
DOMINCK
My back windows do not go down. Front window passenger side works only from driver's side.
  • 54,350 POSTS
This sounds like you have a main window switch that is out. Here is a guide to help you test to confirm the failure:
This will show you how to test the switch here is a wiring diagram to show you how the system works.
Cheers, Ken
KATHYBEL
Window will go down, but won't go up. sometimes if you flip the button up and down and hit the inside door panel by window controls it will go up, but takes some playing and saying some choice words.
  • 110,190 POSTS
Welcome to 2CarPros.
The power window motor changes direction based on polarity. Basically, there are two wires to it. If power enters in one wire, the motor runs one direction. If power enters on the opposite wire, the motor goes the other direction.
Now, take a look at picture 1. It shows the two wires coming from the window master switch on the driver's side. Based on which direction you turn the switch determines which wire gets power. If it isn't the driver's door window, let me know.
My first suspect is the switch is going bad. To check, you need to remove the door panel to access the switch. Then using a test light, check to see if power goes to the motor when you select up. The wires going to the driver's side window motor are white and the other is light blue. The light blue one is in question. That is the wire which receives power when you request the window to go up. So, using that test light, check to see if the switch sends power to that wire when you try to put the window up. If it doesn't, replace the switch. If there is power, check the wire to the motor and it's connections.
As mentioned in the prior response, it is getting older, but the motor doesn't care which way it turns. If it works one way, it will work the other if it gets power. Also, here are a couple links to help with the testing process:
Here is the manual's description of how it works.
Front and rear door window lift motors are of the permanent magnet type. A battery positive and negative connection to either of the two motor terminals will cause the motor to rotate in one direction. Reversing current through these same two connections will cause the motor to rotate in the opposite direction.
If you determine that the switch needs replaced, here are the directions. Pic 2 shows the door panel and fasteners. Picture 3 indicates what type of fasteners are used.
_____________________________
Switch removal and replacement
REMOVAL
1. Disconnect and isolate the battery negative cable.
2. Remove the door trim panel.
3. Remove the switch mounting fasteners.
INSTALLATION
1. Install switch and mounting fasteners.
2. Install door trim panel.
3. Connect battery negative cable.
TERRY11961
2001 Dodge Stratus, 81000 miles, needs brakes, defrost rear window does not work, A/C needs to be charged, fan system does not work (can get heat on hi only), oil change, and tune up. Just had tranny fixed to the tune of $2000.
Fix it or junk it?
SERVICE WRITER
  • 9,123 POSTS
Are you willing to do anything yourself?
Can you get another car in similar shapr for the little money that it will take?
https://www.2carpros.com/car_articles/buy_repair.htm
SWEENER07
  • 16 POSTS
Electrical problem
2000 Dodge Stratus 4 cyl Front Wheel Drive Automatic
The rear windows will not work. the front ones work just fine
BMRFIXIT
  • 19,053 POSTS
If front working that eliminate the possibility of a bad fuse
suspect window motor and or switch at the motor
Remove door panel and check for power and ground
W.STRINGHAM
  • 6 POSTS
1997 Dodge Stratus. Power windows wont work. Checked all the fuses and they are ok. Had dealership reset ECU and they still dont work. Could it be a relay? If so, which one and where?
JDL
  • 16,098 POSTS
Check for voltage at power window relay, goes hot when you turn on the key. #19 in the diagram. Interior fuse box.
W.STRINGHAM
  • 6 POSTS
You must be familiar with this car. That is exactly what I thought. What are the chances of just the relay goin bad? It's a medium sized 2 prong silver capacitor looking thing.
JDL
  • 16,098 POSTS
I looked up your vehicle info in our database. Using a voltage tester and checking for voltage at the relay, key on, is what I do first. I haven't seen very many faulty relays, hardly any.
W.STRINGHAM
  • 6 POSTS
If there is no power at the relay (meter doesn't read any voltage), what would cause that?
JDL
  • 16,098 POSTS
That is ignition feed, comes from ignition switch. I'd have to check feed to and from the ignition switch.
JMOORE86
I have a 2000 dodge stratus but all 4 of the windows have stopped working. The Sunroof still works and they are on the same relay in the fuse box so im assuming its not that. Theres also no light at the 4 switches on the door. Help please its about to be summer.
JDL
  • 16,098 POSTS
As far as the windows, get at the wiring harness, hinge side of driver door. Use a voltage tester, find the tan wire, see if it is hot/voltage. If it is, check black wire for ground. Sometimes because the driver door opens and shuts so much, it can cause the wires to break.
JMOORE86
I'm gonna give this a shot in a cpl days win I get the time I'll let you know how it goes. Thanks for the reply appreciate it.
JDL
  • 16,098 POSTS
No problem, hope you get it going your way.
