Mechanics
HI
Dodge Ram
My 2003 dodge ram has air bubbles in the radiator lines when its running and off why is it doing that and where is it coming from to create the bubbles
Rocky_316
December 26, 2006.
AD
Rocky_316
Dec 26, 2006.
Perhaps i'm off base, but a leaking headgasket will allow exhaust fumes to be compressed into the cooling system. A chemical check of the air bubbles can be performed to verify.
So prehaps its my headgasket then is why the airbubbles are running threw the raditor
Rocky_316
Dec 26, 2006.
The headgasket when breached can allow exhaust fumes to be compressed into the cooling system.
The headgasket is between the cylinder head and the engine block (on top of the cylinders). There are coolant passages nearby that can be exposed to the compression of the cylinders if the gaskets fails there.
The coolant continues to circulate carrying the air bubbles until the surface.
This may not be what is happening, but MAY be.
Get it looked at.
AD
