Mechanics
REMOVING FRONT BRAKE ROTORS ON 3/4 TON
2005 Dodge Ram
Drive Train Axles Bearings problem
2005 Dodge Ram V8 Four Wheel Drive Automatic 115000 miles
I removed the brake calipers and the nut from the axel but rotor does not budge.I'm not a mechanic by any stretch of the imagination but I've never had this trouble before, although i've never worked on a 3/4 ton before, I would appreciate any input on this subject
AD
Rsroughneck
August 12, 2009.
Rotor is just stuck due to brake heat. Use a rubber headed mallet to bang the rotor loose.
Bluelightnin6
Aug 12, 2009.
AD
