2004 Dodge Ram Transmission
2004 DODGE RAM
38,000 MILES • V8 • 4WD • AUTOMATIC
CALE030785
When I'm speeding up the tranmission will shift up prematurley and I have to give it more gas to shift down. Also after it has warmed up and I try to maintain speed at about 30 mph the tack will bounce from 1500 to 1000 rpm and when I try to stop it will shift down hard and when i get stopped the trans wont disingage and it will jump forward and do the same in reverse also when I go from drive to neutral it will clank and when i go back into drive it will squeal alittle and then start grabbing and the same for reverse. When it grabs I really have too push the breaks hard to keep it from moving, also when i put it into four high it will really bog the engine down.
Jan 23, 2010 at 7:14 PM
