Mechanics
DODGE RAM CLUTCH PROBLEM
2003 Dodge Ram
Air Conditioning problem
2003 Dodge Ram V8 Four Wheel Drive Automatic 101000 miles
my ac works only when I drive it gets cold the fan works fine its when I come to a stop it start to blow hot air when I go again it blows cold again can anyone help me
Tony melcher
July 4, 2009.
Hello, I'm not an ac tech, but, when the problem occurs, raise the hood and see if the ac compressor clutch is engaged? If it isn't, check the wiring connector for B+ and ground. If that checks ok, suspect something wrong with compressor. I have heard of the clutch coil causing a problem.
JDL
Jul 4, 2009.
AD
