2003 Dodge Ram
Electrical problem
2003 Dodge Ram V8 Two Wheel Drive Automatic 82000 miles
my abs and brake lights are on wat is problem brakes are 6months old all way around been replaced brakes work good.1 more question my gage that for my hot and cold reading keeps on going past the hot side both sensor been disconnected and still going to the hot side therostat has been replace full fluid but radiator found out it has hole it could that cause gage to go to hot side
June 15, 2009.
Anti-Lock Brake System (ABS) allows driver to stop VEHICLE in shortest distance while maintaining steering control. During normal anti-lock operation a pulsation in brake pedal and a clicking sound will be sensed.
System consists of a master cylinder/booster assembly, ABS control module, Hydraulic Control Unit (HCU), electric pump/motor, Brake Pedal Position (BPP) switch (also functions as brakelight switch), 4 wheel sensors, and 2 warning lights
need to have it scanned for codes
as for the Overheating if the radiator is leaking coolant,
than you should have it replaced 1st and check the water pump
should not let the engine overheat or engine failure will occur
Jun 15, 2009.
