Mechanics
HEATER NOT BLOWING HOT AIR
2002 Dodge Ram
Heater problem
2002 Dodge Ram 6 cyl Four Wheel Drive Automatic 83000 miles
I have a 2002 Dodge Ram that the heater isn't blowing warm or hot air. I flushed the heater core and know it's not plugged. Have checked the fuse's and relay's nothing wrong there. Anyone have any ideas? Thank you.
Carnut95252
October 28, 2008.
If your truck has a heater control valve, you should check it out; it may be stuck closed. Is your outlet heater hose hot when heat is on? If so, your valve is probably okay.
You could also have a problem with your actuator or the blend door/damper.
RenaudTN
Oct 31, 2008.
AD
