Front brakes were dragging and overheating?
2006 DODGE RAM
160,000 MILES • 5.9L • 6 CYL • 4WD • AUTOMATIC
VELF
  • 5 POSTS
Front brakes were dragging and overheating causing loss of power. Installed new calipers, hoses, master cylinder and rotors. Vehicle is driving fine but front brakes are still overheating. Caliper pistons are not retracting when pedal released. Vehicle has four wheel ABS.
Oct 3, 2017 at 11:08 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,349 POSTS
It sounds like you have a push rod extended out to far from the booster. Did this happens after the brake job has done or before? Try to loosen the master cylinder mounting bolts three turns to see if the brakes release. Please let us know what happens and upload pictures or videos of the problem.
Oct 4, 2017 at 1:58 PM
VELF
  • 5 POSTS
I have Ram 2500 mega cab 2006. There is no way to adjust a push rod. I changed master cylinder, booster, ABS, and calipers. Still dragging little bit in front. I was thinking the caliper brackets, but they look normal.
Oct 4, 2017 at 2:24 PM
  • 54,349 POSTS
It sounds like the caliper slides are seized up, I would remove the caliper and service the slides.
This guide can help
https://www.2carpros.com/articles/a-comprehensive-guide-to-fixing-automotive-brakes-locking-up
Please go over this guide and report back.
Oct 6, 2017 at 9:32 AM
VELF
  • 5 POSTS
Not freely
Oct 6, 2017 at 9:39 AM
  • 54,349 POSTS
Can you crack one bleeder to see if they turn freely?
Oct 6, 2017 at 11:23 AM
VELF
  • 5 POSTS
No pressure in a system. I can crack any hose or bleeder and no changes
Oct 6, 2017 at 3:52 PM
  • 54,349 POSTS
The caliper sides sounds like they are frozen. Here is a guide that shows how to service them. If that is not it then the calipers must be sticking mechanically which is rare but it happens.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
and
https://www.2carpros.com/articles/brake-caliper-replacement
Cheers, Ken
Oct 7, 2017 at 11:46 AM
FEL1X310
I've been having trouble with my truck, I ride around for about 15-20 minutes and the front calipers seem to seize up, with smoke coming out from them. I just recently had the master cylinder, 2 front calipers, brake pads and I'm still having the same issue. i don't know what to do anymore. thanks
Feb 27, 2021 at 11:31 AM (Merged)
  • 110,190 POSTS
Were the rubber brake hoses to the caliper replaced?
Try this. Safely lift the front of the vehicle. Have a helper apply the brakes. Once released, is the wheel still locked? If it is, open the bleeder on the brake caliper and see if the wheel can then be turned. I attached a pic below of the bleeder I am referring to.
If the wheel is locked and releases when you open the bleeder, the rubber hoses are bad and need replaced. If the wheel remains locked, then you have a caliper issue.
Let me know what you find when you perform the test. At that point, I will know better what to do next.
FEL1X310
Hey Joe, I lifted the truck after I took it for a spin and the wheels were locked in. so I released the bleeder and the wheels were able to turn freely. I swapped the rubber hoses and took it out for a spin and no luck, they locked up on me as well. any advice on what to do next? thanks.
  • 110,190 POSTS
Interesting. If they released when you opened the bleeder, then we know the calipers aren't the issue. Go all the way back to the master cylinder and do the same thing to see if they release. If they do, the problem is between the pedal and MC.
If that is the case, I suspect that when you installed the new master cylinder, the push rod wasn't aligned properly into the rear of the master cylinder. If the brakes drag even slightly, they will heat up. When that happens, brake fluid expands and will cause them to get tighter and tighter until they lock.
I attached a pic of the rod I'm referring to. Take a look through these directions for MC replacement. See if you did what is explained. I circled the part I'm referring to in the second pic. I have a feeling this is what is wrong. However, if you try the last test I suggested, we will know if it is between the pedal and MC. I can't think of anywhere other it could be, but better to check.
__________________________
2003 Dodge or Ram Truck RAM 1500 Truck 2WD V8-5.7L VIN D
All Except Hydroboost
Vehicle Brakes and Traction Control Hydraulic System Brake Master Cylinder Service and Repair Procedures Master Cylinder Removal and Installation All Except Hydroboost
ALL EXCEPT HYDROBOOST
REMOVAL - ALL EXCEPT HYDROBOOST
pic 1
1. Remove the brake lines from the master cylinder.
2. Disconnect the electrical connector for the low fluid level.
3. Remove the mounting nuts from the master cylinder.
4. Remove the master cylinder.
NOTE: Using care remove the master cylinder directly forward in order not to dislodge the output rod from its seat inside the booster.
INSTALLATION - ALL EXCEPT HYDROBOOST
NOTE: If master cylinder is replaced bleed cylinder before installation.
pic 2
NOTE: Make sure the output rod of the brake booster is in position before mounting of the master cylinder "This position will enable the output rod to enter inside of the master cylinder plunger sleeve during installation". Proper position is obtained when the output rod is centered perpendicular to the master cylinder mounting hole.
NOTE: Before installing the master cylinder, pump the brake pedal several times with the engine off to remove vacuum from the booster.
1. Install the master cylinder on the booster mounting studs.
2. Install new mounting nuts and tighten to 25 Nm (221 in. lbs.)
3. Install the brake lines and tighten to 19 Nm (170 in. lbs.)
4. Reconnect the electrical connector for the low fluid level switch.
5. Fill and bleed the base brake system.
______________________________
DICK LORENZEN
2003 dodge ram 2500, Front right brake was sticking on, replaced caliper on that side, blew out hose to make sure it was clear. Reinstalled all and bled off brakes. That side is better, now the left front side is stuck on. Any suggestions?
CARADIODOC
  • 34,309 POSTS
Before you replace that caliper too, (they should always be replaced in pairs), crack the steel line nuts at the master cylinder to see if the brake releases. If it does not, open the left front bleeder screw. If it still doesn't release, the piston is sticking in the caliper. If it releases only at the bleeder screw, look for a metal anchor bracket in the middle of the rubber hose. It's very common for rust to build up inside the area that is crimped around the hose. That will constrict it and prevent fluid from returning to the master cylinder. Open that crimp up a little with a channel lock pliers.
There is a 32 page service bulletin on preventing brake pull when hot, and it only applies to trucks with diesel engines or the 3500s. Of particular importance, there were four different calipers available for each side on the front. That might not apply anymore to a 2003. That bulletin was from the 1990s.
caradiodoc
2CP-ARCHIVES
  • 4,540 POSTS
my front brakes get smoking hot after i drive my truck 6 miles in traffic
i replaced calipers pads in front and the problem remains
no ligths in dashboard to check
i a dodge ram 2500 4x4 diesel thanks
CARADIODOC
  • 34,309 POSTS
Next time they lock up, park on a slight incline, shift to neutral, and crack open the steel lines at the master cylinder. If that lets them release, suspect contaminated brake fluid. If they do not release, open the bleeder screws. If that lets them release, suspect the rubber flex hoses are restricted.
GARY THE HORSE GUY
got a problem that just surfaced with our front brakes on our truck. the front brakes are hanging up...not all the time but it has hung up twice when we were only a couple miles from home so we just drove home but the brakes were hot and really smelled i have not pulled the wheels off but i am sure that the pads are fried but what caused them to hang up?
Feb 27, 2021 at 11:32 AM (Merged)
  • 110,190 POSTS
A few things could cause it. The most common is the caliper pistons wear and stick. Also, it is very common for the slides on the caliper (from corrosion, dust, rust) no longer slid as easilly as they should causing the brakes to stick. I have also see (rare) that the rubber brake hoses connected to the caliper have deteriated inside and will allow fluid to enter the caliper to stop, but won't allow the fluid to return which causes the brakes to stick.
I would recommend removing the calipers and checking them.
Let me know what you find.
KUDLES
I have a dodge ram 2500 cummins, the front right wheel appears to be locked up when moving forward, all of the other wheels rotate but this one. The truck will reverse fine with no lockup.A friend of mine seams to think it could be the caliper but he is no engineer.It is my family's only mode of transport and is killing us not having it so any help is much appreciated.
  • 110,190 POSTS
Is the tire actually skidding? As far as your friend, he may be correct. However, it is odd that is unlocks in reverse. Therefore, I recommend checking the caliper to make sure it is tight, and the pads are properly positioned and in good condition.
It everything looks good, then check to see if the caliper piston is free moving (not stuck) and make sure the slides are not sticking. It that is all good, replace the rubber brake hose that goes to the caliper. I have seen many times where the hose deteriates inside. It allows pressure to go one way and not the other. As a result, the brake won't release.
KUDLES
I actually worked it out, I took the wheel off to check the caliper, appears that a bolt had come out of the caliper bracket so the caliper/bracket was sitting on the brake disk.
Thanks for your reply.
  • 110,190 POSTS
I'm glad you fixed it. When you said it locked going forward and not in reverse, I had a feeling the caliper was loose or you lost a bolt.
Thanks for using 2carpros.com and let us know if you have questions in the future.
ELECTRICFENDER
Replaced rear shoes, adjusted brakes properly (including the parking brake), now both drums get very hot (too hot to touch) after about 10 miles of driving. I'm not sure if they got hot before as I never touched them. Put truck back on lift, rechecked all adjustments - everything normal. Still overheated. Back on lift, pulled drums, inspected installation, backed off self adjusters completely, loosened parking back cable completely. Nothing is dragging or rubbing, but drums still get very hot after a few miles of mixed driving. Axle, (near rear wheel bearing) is cool to the touch, so I assume my bearings are OK (no noise from them anyway.) Backing plate is warm but is much cooler than the drums. First time I've ever seen this!!! Help!!
  • 110,190 POSTS
Hi:
It is normal for the drums to get hot if the brakes are working. If you adjusted them until you got a slight drag (but can still turn the wheel easily) they should be fine. Keep in mind, friction is what stops you so heat is normal. If they are smoking, I would be concerned.
DOGGIE505
92 dodge ram van braley touching brake pedal locks front wheels. put new master on it this stoped it for about a month just started doing it again. porpoting valve mabe?
Feb 27, 2021 at 11:33 AM (Merged)
  • 110,190 POSTS
If they are locking up, make sure no grease or brake fluid is getting on them. If they are clean, dry, and not sticking, the proportioning valve is what determines how much pressure goes to them in relation to the rear. However, unless the check ball is stuck in the valve, I wouldn't think they would lock up. Just for the heck of it, try bleeding the brakes to see if that moves the check ball in the prop valve. Do them in the correct order (RR, LR, RF, LF). If that improves the problem, see if it happens again, If it does, replace the proportioning valve.
CHOLDREAD
My Father bought this truck new and I am unsure if it was a 1985 or a 1986. The brakes have always been very touchy. There is very little feel to the brakes and they make the truck something that we would not want to drive in snowy road conditions. Was this a common problem for the 1985/1986 model years? Is there a fix for it or was it just something that was part of the model line?
CARADIODOC
  • 34,309 POSTS
Wrong master cylinder. Install one with a smaller bore.
Also, someone may have installed larger diameter rear wheel cylinders. There was a service bulletin about installing one size larger wheel cylinders to alleviate rapid front brake pad wear. You could also go two sizes larger if you knew your customer's truck was always heavily loaded, but you had to buy those from a GM dealer. They were not available from Chrysler.
A stuck combination valve can do this too. The metering valve section prevents front brake pad application until the rear shoes have moved out far enough to contact the drums. If the valve is stuck open, the front brakes will apply too soon.
caradiodoc
