1999 Dodge Ram
Engine Performance problem
1999 Dodge Ram 6 cyl Two Wheel Drive Automatic 87000 miles
when started engine will run fine than after about 200 yards of driving and at a standing idle you hear the idle air control motor starting to open and while thats happening the rpms drop and engine runs rough. (Lean) a sniff of carb spray will bring idle up and run fine for about 2 min. Tryed a new idle air control motor, fuel pump, throttle position sensor, lower intake manifold pan (in the valley, bottom side) gasket, setting sync. Signal/dist. Resetting all adaptives with scanner, all didnot fix problem. Please help cause the parts bazooka is real low on ammo!
May 5, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
