4X4 5.9 145000 HEATER CORE NOISE
1999 Dodge Ram
Thanks for the other response so here is another question.
I had the waterpump replaced and new heads installed a few weeks ago. Ever since it sounds like water pouring coming from the heater core. I tried to bleed the air from the coolent system as well as had a shop try. How do I get the air out? I though about finding a steep hill to park on to see if I could burp the air out that way. There has to be a trick one of you guys are aware of. They also replaced the thermostat too. Engine temp is fine, as well as heat works.
Thanks again for a great site.
May 10, 2007.
Have someone vaccumn fill your cooling system.
Les Dane
May 11, 2007.
