Crankshaft sensor location?
1998 DODGE RAM
4WD
MONICADAVISROPER
Where is crank sensor located on the truck listed above? The truck is a 1500 model with a 360 engine four wheel drive 5.9L. Can you show me a picture?
Jun 8, 2011 at 5:45 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
The sensor is bolted to the top of the cylinder block near the rear of right cylinder head.
Here is a guide and diagrams below to show you how to change the sensor out:
Jun 8, 2011 at 5:49 PM
LUCASTOWING77
1999 Dodge Ram 6 cyl Automatic
Where is the crank sensor located under the hood?
Dec 15, 2020 at 10:09 AM (Merged)
Crankshaft position sensor. Check out the images (Below). Please let us know how it goes
DUSTONM
I ran my codes my crankshaft sensor is messing my motor up. i bought the sensor and cannot find the sensor on my truck. where is it?
Dec 15, 2020 at 10:10 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
engines the crankshaft position sensor is located at the rear of the engine block. Check out the images (Below). Please let us know what happens.
SARGENT1
im trying to locate the sensor to replace but cant find it. i know its on the belt housing but i still cant locate it .ill appreciate any help.
thanks
steve
Fig. 25 Crankshaft Position Sensor - Typical
https://images.2carpros.com/forum/automotive_pictures/12900_cps_52.jpg
The sensor is located on the top of cylinder block near the rear of right cylinder head.
CARLAR14
where is the crankshaft position sensor located in a 96 dodge ram 2500 v10
WRENCHTECH
  • 20,761 POSTS
The crankshaft position sensor is located in the side of the block here isa guide to help walk you through the steps and diagrams and instructions to help you do the job on your car.
SHOLYNNE
  • 6 POSTS
We need to replace the CPS on our truck and we cannot get the sensor out. The bolt is out but no matter how much we wiggle and tug the sensor will not come out. Is there something we are missing? I cannot find information anywhere on what the secret is on this engine. Help please!
CARADIODOC
  • 34,309 POSTS
There are two bolts holding it in.
SHOLYNNE
  • 6 POSTS
V10 has 3/8 standard bolt. There is no second bolt unless it is hidden in some secret compartment.
CARADIODOC
  • 34,309 POSTS
I have only replaced a couple crank sensors on this engine, but they all had two bolts.
This photo is for the sensor for a 1993 model, but it looks the same for both years. The photo for the sensor shown for your year is too small and it does not show the shape of the plug. I just used this photo because it is easier to see.
SHOLYNNE
  • 6 POSTS
There is only one bolt for the V10. The attached photo shows the only place for the bolt that goes into the block. The problem is this is a couple of inches long and there is about one inch of room between the CPS and the engine mount that is not allowing it to be removed do to space limitation. Unless someone knows a trick, the only thing we can figure is you have to take out the engine mount.
CARADIODOC
  • 34,309 POSTS
That looks more like a camshaft position sensor but the mounting ear is different. I looked at a number of different years for cam and crank sensors and did not see anything like what you have. I assume you cannot just rotate the ear away from the obstruction?
Now that you mention engine mounts, the crank sensors I have replaced have always been in the transmission's bell housing, right behind the right cylinder head.
SHOLYNNE
  • 6 POSTS
I will try to get a picture but where it is, is such an awkward tight spot I don’t know that i can get a phone even in there to take a picture.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The Camshaft position sensor is located on left side of timing chain cover.
The Crankshaft position sensor is located lower right side of cylinder block.
SHOLYNNE
  • 6 POSTS
Thanks for pointing out I called it the wrong thing. My bad. I know where the part goes. I even included a picture to show I knew what part it was. Now back to my question. How to get a two inch part out with one inch of space without taking the motor out of the truck.
I called it the wrong part. My question was not about what the part was called. It was how to replace the part. I included a picture so I obviously know what the part is and where it goes.
BLAZETRINI
Yea Im just wondering where the crankshaft sensor is located in my truck
this site is great and thanks.
BMRFIXIT
  • 19,053 POSTS
Here is a guide to help you see what you are in for when doing the job.
Here is the location for your car
Check out the diagrams (Below)
Cheers
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Using two small screwdrivers, use a rocking motion and carefully pry sensor from timing chain cover.
SHOLYNNE
  • 6 POSTS
Its on the side of the block. Not on the timing chain cover. The motor mount is blocking it so it cant be wiggle out from what we can tell. Its a V10 so completely different than a V8 and V6.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If the motor mount is in the way, perhaps you will have to loosen it up, try to move it out of the way enough, maybe have to jack up the engine a little bit in order to do so, or remove the motor mount.
You know just because you are holding a new part in your hand, doesn't mean it's the correct part. Although I am convinced you are trying to replace the crank sensor, it appears that new part you are holding is the cam sensor.
To be sure, can you post the brand name, part number and where you bought that sensor?
SONNYTHOMPSON
  • 5 POSTS
when driving a while engine will no start, dianosed bad crankshaft sensor, won t start when warm, after cooling starts again and dianosed bad sensor not detected. Installed new sensor still doing the same thing
Dec 16, 2020 at 8:02 AM (Merged)
HMAC300
  • 48,601 POSTS
rescan for codes and check fuel pressure first. should be 44-54 psi
SONNYTHOMPSON
  • 5 POSTS
scanned first said bad crankshaft sensor, I replaced it and the same problem when warm won t start scan reads bad sensor, when cool restarts no scan codes
SONNYTHOMPSON
  • 5 POSTS
fuel pressure ok no spark when this happens
HMAC300
  • 48,601 POSTS
if you can do a wiggle test on cranks sensor wires, the connection may be bad on that. it can also be a bad connection at pcm. also replace asd relay with a like one and see if that helps.
SONNYTHOMPSON
  • 5 POSTS
now I get code P3040 camshaft sensor and can t find one
HMAC300
  • 48,601 POSTS
it's inside distributor
SONNYTHOMPSON
  • 5 POSTS
Dist coil switch in distributor was the problem thanks much
HMAC300
  • 48,601 POSTS
that is the camshaft sensor glad you got it fixed......
