Mechanics
CHANGING UPPER BALL JOINTS
1996 Dodge Ram
Suspension problem
1996 Dodge Ram V8 Two Wheel Drive Automatic 196000 miles
how do you change upper ball joints?
Mo19619
June 4, 2009.
Raise vehicle, and position safety stands under frame. Remove wheel.
Remove shock absorber and coil spring.
Remove brake caliper retainer and brake caliper. Support caliper aside.
Disconnect ball joint.
Remove pivot bolts and control arm.
Support control arm in vise.
Using Ball Joint Wrench (C-3561 ), unscrew ball joint from control arm.
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_376.jpg
BMRFIXIT
Jun 4, 2009.
