1995 Dodge Ram Repair Question
Topics covered: Axle, Dent, Four wheel drive.
Asked on July 30, 2009
1995 Dodge Ram It wasn't just the u-joint II
Drive Train Axles Bearings problem
1995 Dodge Ram V8 Four Wheel Drive Automatic 185000 miles
Skip the first question. The nut spun off the yoke which allowed it to pull into the casing and nearly every component was wrecked. Mostly worn parts with that many miles and neglect caused the catastophic failure. The pinion shop had another truck identical to it sitting there with the same problem. CHECK THE DIFF! When replacing U-joints on a Dodge!
