1995 Dodge Ram
Within a week of purchase in 1995 (I bought the truck new and I was the only owner), the batteries died. I took it back and the dodge dealers replaced the batteries. That set last a month before the batteries failing again. Took it back, and the dealer said that both batteries were dead again, and they were replaced again. The did a system check and couldn't find anything wrong. Within a month, the batteries failed again. This time I called Dodge and told them that this was a significant problem and if they couldn't fix it they could replace the truck. They sent out an " expert" to look at the system and he checked it and couldn't find anything wrong. They replaced the batteries again. To this point I had been using Dodge batteries. That set worked 5 years. Then I replaced the batteries at Sears. Those batteries ran another 5 years, so I thought the problem was gone. Recently, I replaced the batteries again, and they died within 2 days. You took them back to Sears and they tested it and said that one battery was dead and the charging system was fine. If I run them within a day, the batteries are fine, it seems, but if I just let it go, the batteries die. They've died twice, recently.
So, the first time they dies, I hooked it up to my battery charger. When I went back to check, the charger had fried. The charger was connected correctly, leading me to believe that there was a short and has been all along.
I'm wondering if its the glow plugs. I've never replaced them - if that matters. The truck has 137K miles. Hope that's sufficiently detailed, the truck is outside (60 degrees), and dead.
November 24, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
