2001 Dodge Other
Hello : :
\\ 2001 Dodge Stratus 123,000 Miles
Phoenix, AZ. It's about 112 today. A couple days ago the Stratus started overheating, and in the time that I have had to drive since then I have observed the followiing.
- It only begins to overheat when I am not moving, at a light or something. If I am on the freeway the entire time, I don't have a problem.
- There are 2 fans behind the front 'grill' that do not seem to be running at all.
- I have been replacing water into the radiator before any trips over the past 2 days.
- The coolant level seems goods.
- Over the past 2 weeks maybe once or twice the car overheated while cruising and running the a/c, but when it did, the temperature gauge went up.
- It does not go up anymore.
- When I get stuck at a light, the engine seems like it is knocking around, and then is weak or barely got a grip when I apply gas, but then once I get over 5 or 10 mph, it is good again.
. I just got an oil change at Midas a week and a 1/2 ago. I also know that I need motor mounts here soon.
Through conversation the only theory I've come up with is that a fan belt has busted?
It truly appreciate any help on this. ThanksQ!
June 5, 2006.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
