2000 Dodge Other Repair Question
Topics covered: Sensor, Ignition coil, Rim.
Asked on August 2, 2006
Intrepid error codes
2000 Dodge Intrepid 160,000 miles
I bought OBD-II scanner. Error Codes:
1. P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
2. P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
3. P1391 Glow Plug Circuit Low Input (Bank #1)
Glow Plug? Is there another explanation for P1391?Once car reaches normal operating temp., the engine misses as if starved.
UPDATE: I read further about P1391 and founf it was cam position sensor and/or crankshaft sensor. I took the cam position sensor out and cleaned it. Re-installed it and VOILA! It appears to be fixed. No missing as of yet.
