Mechanics
MODELS FUEL INJECTORS STICKING OPEN
1997 Dodge Other
Computer problem
1997 Other Dodge Models V8 Two Wheel Drive Automatic 212000 miles
It has coded out the throttle body sensor which was replaced along with coolant temp sensor and manifold air intake sensor. Problem has gotten steadily worse with 2 injectors hanging open when it happens
Mcsmack
July 29, 2008.
Hi: If the fuell pressure falls within spec, replace the injectors. The popit valve is most likely worn.
AD
