1988 Dodge Omni Repair Question
Topics covered: Coolant, Engine, Engine performance.
Asked on September 2, 2008
1988 Dodge Omni engine
my omni sucks down water and gets hott
Answer
Replied on October 2, 2008
Hi:
It sounds like you have a head gasket, water pump, radiator, rad hose, freeze plug or cracked block. Can you see where the water is coming out? If you loose the coolant, then the vehicle is going to run hot. Let me know if you can see where the water is coming from and I'll try to better advise you.
Thanks,
