Mechanics
STALLING HAPPENS WHEN I AM STOPPED
2002 Dodge Neon
Engine Performance problem
2002 Dodge Neon 4 cyl Two Wheel Drive Automatic 90,888 miles
For 3 months now, my neon has been stalling every now and then when I stop. It started when I had to change my cam shaft sensor, which also caused the car to stall, because it was faulty. After the fix, the car drove fine for a day, but stalled the next day, but not as dramatic as before the sensor was changed. A year ago my girlfriend's neon also stalled when it came to a stop at around the same mileage. Come to find out, she was only running on 3 cylinders and the 3rd cylinder was not holding the pressure. Could this be what is happening to my neon? Could this have anything to do with the O2 leak that my computer recorded a year ago and I did nothing about?
Pdasilva18
October 16, 2008.
Have the PCM scanned for error codes. If you have a cylinder misfire, it could cause stalling.
But the best place to start is to get and anaylize any error codes.
Mmprince4000
Oct 16, 2008.
AD
