2CarPros - Car Questions & Answers
2000 Dodge Neon Repair Question
Topics covered: Coolant, Engine, Pressure test.
Asked on June 18, 2009
2000 Dodge Neon High Coolant Temperature
Engine Cooling problem
2000 Dodge Neon 4 cyl Front Wheel Drive Manual
My dodge neon temperature gauge goes up while vehicle is running but starts to go down while stopped. When I turn off the car, coolant starts flowing into the reservoir tank and is very hot. There are no leaks, already flushed the system, replaced thermostat and fan is working properly. What else should I do?
Avatar Asked by cbeyza
Answer
Replied on June 18, 2009
You sure its not airlock in the system?
Check the radiator if its clogged-up and water pump if both okay get it block and pressure tested-
Tiny Answered by rasmataz
68 questions asked
Replied on June 23, 2009
How do you check for trapped air? how can I get it out in case that's the problem?
Tiny Response from cbeyza
1 question asked
Read below
http://www.2carpros.com/forum/automotive_pictures/12900_cooling_system_bleeding_1.jpg
68 questions asked
