2000 Dodge Neon Repair Question
Topics covered: Clutch, Clutch cable, Clutch pedal.
Asked on February 22, 2008
2000 Dodge Neon CLUTCH
ok i have a 2000 chrysler neon (not dodge for that year) and my clutch pedal has no pressure... (the clutch does not engage when pressed) i took the clutch CABLE (that year was cable not hydraulic) and it was not broke so i figured well its a cable cables stretch.. so i went out and bought a new one... put it on and still the same problem... its like when i push the pedal in the little "V" shape thing in the motor does not pull back but yet i can pull it back with my fingers if i do so just with alot of force... help me please ASAP!!!!
Answer
Replied on February 23, 2008
ask a helper to step on the clutch for you as you watch under the hood side of the cable
if it moves the level
then the clutch / pressure plate no good
you have to drop the tranny and check inside
good luck
