Mechanics
TURN OVER BUT WON'T START
1997 Dodge Neon
Engine Performance problem
1997 Dodge Neon 4 cyl Front Wheel Drive Automatic 134373 miles
I have a 97 Dodge Neon DOHC that will not start. I have change plugs, plugs wires, coil, and the fual pump. It will turn over but it won't start. Please help. Thank you for you time.
Lobham
February 23, 2010.
Do you have a check engine light? And when was your last tune-up?
Cranks but no start condition: Fuel and Spark: Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
AD
Rasmataz
Feb 23, 2010.
I had a 97 as well and in the engine compartment is a fuse box check those fuses.I had the same sounding problem and thats where my problem was. Check it out
Dodge 2010
Feb 23, 2010.
AD
