Fuel pump?
MALIBU1320
  • 1999 DODGE NEON
Where is the fuel pump located on the 99 neon? Also, spedometer only works half the time? Causes?
Monday, March 29th, 2010 AT 7:32 AM
Hi malibu1320, Welcome to 2carpros and TY for the donation
The fuel pump is in the fuel tank
You might want to inspect and test the vehicle speed sensor located in the transmission extension housing.
https://www.2carpros.com/forum/automotive_pictures/12900_vss_26.jpg
Monday, March 29th, 2010 AT 7:48 AM
JIADEE04
  • 1998 DODGE NEON
  • 4 CYL
  • MANUAL
  • 235,000 MILES
I need to replace the pump but how do I drain the gas out of it?
Thursday, December 17th, 2020 AT 8:33 AM (Merged)
CAR TOM
  • 45 POSTS
There are no fuel dump doors, you are going to have to pull the fuel out of the gas fill door with a hand held pump which can be purchased in automotive or camping stores
BANDZILLA92
  • 1998 DODGE NEON
  • 2.0L
  • 4 CYL
  • 4WD
  • MANUAL
  • 192,000 MILES
When I drive the car it is only a matter of time that my car will shut off on me with the fuse blown out. I replace the fuse and the same keeps happening. I've gone to auto stores to try to get the fuel filter replaced and they don't carry them because they are non replaceable. Need help getting down to the real problem. Please and thank you. Highly appreciated. : )
Thursday, December 17th, 2020 AT 8:34 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
The problem here is probably a short to ground in the fuel pump circuit. A short to ground will blow the fuse protecting the circuit because of laws governing electricity, Ohm's Law. Electricity can be broken down into three components, Voltage (Electrical pressure), Current/Amps (Electrical flow), and Resistance (Anything that opposes electrical flow). Ohm's law states that if one of the three components is constant (one always is in automotive electrical Voltage (12VDC) and another goes up (Amps) than the last one must go down (Resistance). This is a short to ground because the voltage is not making it to the load (fuel pump) because you have a bare wire somewhere touching ground. With no resistance the Amps (Electrical Flow) will go up until it overtakes the (20A) fuse and "pop" the fuse blows, just like it is designed to. Find the damaged wire in the circuit and repair it and you have fixed the problem.
I have included wiring diagrams for you in the diagrams down below with the fuel pump wires highlighted. Please find the short and get back to us with what you find out.
Thanks,
Alex
2CarPros
KASMO3
  • 1997 DODGE NEON
  • 4 CYL
  • 135,000 MILES
Can the fuel pump be reached thru the back seat of car or does it have to lifted with jack? Live in Az and its very hot here, so before my friend comes to fix it, we need to see if any short cuts can be made.
RICHZOMBIE
  • 173 POSTS
Couldn't find anything on going through the back seat, but here is a step by step for you.
Fuel Pump Removal
Disconnect the negative battery cable
Release the fuel pressure from the fuel system
Remove the gas cap
Drain or siphon the remaining fuel from the fuel tank, into an approved container
Raise and support vehicle
Disconnect the fuel line from the fuel filter
Disconnect the fuel line from the fuel pump
Disconnect the wiring harness from the fuel pump module
Position the transmission jack under the fuel tank for support
Remove the fuel tank straps
Lower the fuel tank for access to the fuel pump
Make sure the area around the fuel pump is clean; you do not want dirt particles going into the fuel tank after the fuel pump is removed
Using the fuel pump module ring spanner, remove the fuel pump lock nut
Remove the fuel pump o ring from the sealing area on the fuel tank
Back to top
Fuel Pump Installation
Clean the sealing area on the fuel tank
Install the new o ring on the fuel tank
Install the new fuel pump; make sure the alignment tab on the bottom side of the fuel pump module engages with notch in fuel pump
Install the fuel pump lock nut
Hold the fuel pump in place while tightening the lock nut to torque specifications
Using the transmission jack position the fuel tank back in place
Install the fuel tank straps, and tighten to torque specifications
Remove the transmission jack
Remove & install new fuel filter
Connect the fuel line to fuel filter
Connect the fuel line to the fuel pump module
Connect the wiring harness to the fuel pump module
Lower the vehicle
Refill the fuel tank
Install the gas cap
Reconnect the negative battery cable
WILLOWMCDORMAN
  • 1997 DODGE NEON
I have a 97 dodge neon that a friend gave to my husband and I. She bought a new car because the fuel pump fuse continues to blow every time she starts it up. I don't have the money to get a diagnostic for it so I'm trying to fix it myself. Please help!
CARADIODOC
  • 33,741 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a 12 volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it's not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
WILLOWMCDORMAN
Every time we turn the key in the ignition, the fuel pump fuse blows. I just need to know the name of the part so I can buy it and do it myself.
CARADIODOC
  • 33,741 POSTS
You take it to a mechanic who will diagnose it. He will figure out the cause of the problem, then tell you the name of whatever part is needed. There's no way I can know that if you aren't going to test anything. Mechanics don't have it that easy. If the fuse is labeled "fuel pump" logic dictates the fuel pump is shorted and that's the name of the part you want. Experience, however, shows that pumps rarely short so chances are you waste your money on a new pump because I told you the name of the part, then you're angry with me when the fuse still blows.
If you do my light bulb trick, as many intelligent mechanics would do, you can simply unplug the pump, then see if the bulb went out. If it did not, you know the short is still there and it's not the pump. Your choice if you want to spend money on something that very likely isn't needed.
There's actually two different fuses involved with the fuel pump circuit. The second one also feeds the ignition coil pack, injectors, alternator field, and oxygen sensor heaters. None of those things typical short either, and none of them are listed on that fuse. Most commonly a wire going to one of those things is grounded. You can spend all day tearing wire harnesses apart looking for that. Mechanics don't want to waste time that they have to charge you for, so they use my light bulb, then they just push and wiggle the wires to see what affects it. 95 percent of the time there is no part that needs to be replaced when a fuse blows. Most shorts are related to bare wires that are repaired.
WILLOWMCDORMAN
Does this look like it could be the problem? My husband said there is what looks like a wire harness that looks exposed on one end. Does that help?
CARADIODOC
  • 33,741 POSTS
That appears to be the pressure switch on the back of the AC compressor. That is in a different circuit than the fuel pump.
SAWCOOK27
  • 1996 DODGE NEON
Electrical problem
1996 Dodge Neon 4 cyl Manual
I have a 1996 Dodge Neon that started blowing the 20-amp fuse for the fuel pump. I replaced the fuse, and was able to start the engine. Upon a restart, the fuse blew again, after which, I blew through 4 more fuses for the fuel pump trying to start my engine. I even removed the positive terminal off of my battery before inserting a new fuse, but the split second that I reconnected the battery, the fuse would blow again.
I was able to tow to a dealership, where they charged me almost $400 to examine the problem. They found some wires that had been cut by a previous owner, which they proceeded to repair, along with giving me a new harness for them. By "magic" they were able to get the fuse to stop burning out. After a week of this "repair", I was able to get my car back. 2 days later, I proceed to start my car, and my fuse for the fuel pump blew once again. I examined the fuse, and found out that they put a 30-amp fuse in where the fuse box display says a 20-amp fuse. Now they want me to tow my car back in so they want to examine it some more, at my cost. HELP!
Thursday, December 17th, 2020 AT 8:35 AM (Merged)
  • 31,938 POSTS
Hi there,
The fuel pump may be failing and over loading the fuse, they can check this by unplugging the pump and placing a test light in the circuit, if the fuse still blows on 20 Amp it will be in the wiring if not I would be considering the pump.
Mark (mhpautos)
PRHANSON27
  • 1996 DODGE NEON
  • 4 CYL
  • 166,000 MILES
What is causing my fuel pump to have no power?
JDL
  • 16,098 POSTS
Did you check for any applicable trouble codes? Did you check for voltage and ground at the pump connector for the motor? The dark green wire with white tracer is voltage for the pump motor, check with engine cranking. Black wire is ground. Also, do you have spark at the plugs? Injector pulse?
https://www.2carpros.com/forum/automotive_pictures/170934_neon_fuel_pump_1.jpg
PRHANSON27
We checked the voltage. There is no power going to it. The oil pressure switch appears to be fine as well. Its not getting any fuel into the injectors.
JDL
  • 16,098 POSTS
The voltage for the pump motor comes from the fuel pump relay in the power distribution center, under the hood. The computer may not be grounding the relay for some reason, that is why I asked you to check for applicable trouble codes. That is also why I asked you to visually check for spark at the plugs and injector pulse, engine cranking.
You can check for applicable mil codes, yourself. You cycle the key, no crank. Cycle the key on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
At the pump relay diagram, terminal 55 is hot all the time. Terminal 56 is voltage for the coil side of relay, goes hot with the key in the crank position. Terminal 53 is ground for the coil side of relay, controlled by the pcm. When the relay is energized that line with the arrowhead switches to terminal 52, that terminal carries voltage to the fuel pump.
https://www.2carpros.com/forum/automotive_pictures/170934_neon_fuel_pump_circuit_1.jpg
