1995 Dodge Neon Overheating
1995 DODGE NEON
140,000 MILES • 4 CYL • 2WD • MANUAL
DONNASCHULTEIS
I have already replaced the radiator, and water pump, I don't know much about cars, but I am leaking alot of oil and I am no overheating quite a bit, I had the head gasket replaced when I bought the car two years ago, it had 84,000 miles on it then and now has 140,000 on it, I'm afraid it could be the head gasket again but I want to be sure before I replace anything what do you think?
Apr 6, 2010 at 4:42 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
TECHNICAL SERVICE BULLETIN
Whenever performing oil leak diagnosis
carefully inspect the cam sensor area to determine if the leak originates from the seal or from other sources. A leak in this area can be mis-interpreted as a leaking head gasket.
Additionally, whenever a head gasket is replaced, the cam seal should always be replaced to prevent the possibility of the vehicle returning with oil seepage
Oct 29, 2018 at 11:08 AM
