crankshaft sensor location
2000 DODGE INTREPID
135,000 MILES • 6 CYL • FWD • AUTOMATIC
KATHY622
Where is the cam sensor and crank sensor on the car?
Jan 20, 2009 at 3:26 PM
  • CAR REPAIR CONTRIBUTOR
The crankshaft sensor you are looking for is located on the passenger's side of the transmission housing, above the differential housing. The bottom of the sensor sits above the drive plate. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 20, 2009 at 3:33 PM
KATHY622
Thanks you i love this site.
Jan 20, 2009 at 3:56 PM
Good to hear, please use 2CarPros anytime we are here to help.
Jan 20, 2009 at 4:40 PM
SERRANOMAGIC
Engine light came on. Went to Auto Zone to have it put on machine. Machine said crank position sensor was malfunctioning. I baught one, but I don't know where it goes. can you help?
Oct 23, 2019 at 1:47 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle's crankshaft position sensor is located on the right side of the transmission housing. 2.7L shown, others similar
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_314.jpg
CAROLYNN652010
I have opportunity to buy this vehicle but want to know how much repair of the crankshaft sensor costs. Thank you very much!
DOCFIXIT
  • 18,828 POSTS
Car average value $150 cost of crankshaft sensor.
RONAELE
Electrical problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
car starts and stays running till it warms up then the check engine light comes on then it shuts off.
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
When you do get it scanned comeback with the code/s and we'll proceed from there. BTW TY
What's the deal with the CPS how did you came about it? Did you get a code for it-A problem with it will cause a not start/misfiring if its going whack
JESS0707
will like to know specifily where is the position where the cranshaft is located to replace sensor.
Oct 23, 2019 at 1:48 PM (Merged)
  • 110,190 POSTS
If you have a 3.2L or 3.5L, it on the passanger's side of the transmission housing above the differential.
Let me know if this helps.
PIERCESCTT6
  • 10 POSTS
i have a 94 dodge intrepid 3.3l i replaced coil,alternator,and crankshaft position sensor and i still dont have spark.. anything else it could be?
Oct 23, 2019 at 1:49 PM (Merged)
The computer coil driver tells the coil to fire the plugs.
Try this while cranking engine over listen to the injector/s are they clicking. also when key is in On position do you hear the fuel pump. I need to know this before we continue
PIERCESCTT6
  • 10 POSTS
[quote:38908638ba="rasmataz"]The computer coil driver tells the coil to fire the plugs.
Try this while cranking engine over listen to the injector/s are they clicking. also when key is in On position do you hear the fuel pump. I need to know this before we continue[/quote:38908638ba]
is there a specific name for that coil driver
Its integral with the car's computer
