1997 Dodge Intrepid
Electrical problem
1997 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 140000 miles
the car was running great, got in to go and would not start, checked to see if it was firing and its not, checked all relays, cam and crank sensor, all wiring, timing belt, everthing is fine, did find that there is no power to the ignition coil pack which would be why its not firing at the plug, traced those wires to the ecm could that be the problem have done research and found the same thing wrong with others that have replaced the ecu and it still wont fire I also checked the ASD and its working
July 1, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
