Mechanics
DODGE INTREPID AUTOMATIC TRANSMISSION PROBLEM
1996 Dodge Intrepid
I have a 1996 Dodge Intrepid with automatic transmission, 140k miles. Last Thursday drove it to work and everything was fine. Drove home for lunch, everything still fine. Drove back to work, no problem. Got in to go home that night, it wouldn't start. All I hear is starter whirring! Todat tried to turn crank with wratchet and socket and couldn't move it in either direction. What's going on? : Shock:
Aaron Nuss
September 20, 2007.
Did you check the oil
no oil will do it every time
check you, re fluid antifrz oil
if oilis ok pull spark plugs and try turning it
watch for fluid
you may also lost the tensior on the timig belt check that
BMRFIXIT
Sep 20, 2007.
