2003 Dodge Durango oil pressure
2003 DODGE DURANGO
DODGEMOM
Engine Performance problem
2003 Dodge Durango 6 cyl Two Wheel Drive Automatic
my oil pump went out. we replaced the oil pump,oil sensor, oil filter and changed the oil. now, when you first crank the vehicle the oil pressure is good but when you drive the car about two miles the oil pressure drops (bottoms out) and the moter begins the rattle. sounds fine when you first crank it what can be causing the oil pressure to drop? please help cna not drive like this.
May 6, 2010 at 9:17 PM
