Wont shift out of park
COOPY33
  • 2006 DODGE DURANGO
Will not shot out of park. I am pushing the brake as usual but will not shift?
Do you
have the same problem?
Monday, May 5th, 2008 AT 4:03 PM
BMRFIXIT
  • 19,053 POSTS
Check if you have brake light when stepped on brake pedal? check fuses , check brake light switch and its connector. If all okay the interlock solenoid is out here are the fuse locations and the interlock solenoid replacement instructions in the diagrams below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Friday, May 9th, 2008 AT 6:38 PM
WAYNEL
Thank you for this post I had this problem and had to replace the solenoid cost me $134.00 all fixed I love this site.
Monday, November 18th, 2019 AT 1:19 PM
LINCOLN23
  • 2002 DODGE DURANGO
  • V8
  • 4WD
  • 106,000 MILES
I cant get my 2002 dodge durango to shift into gear (neutral, drive, etc) it wont go out of park. Do you know what maybe wrong with it? I push the brake and pull on the shifter but it doesnt budge.
Monday, November 18th, 2019 AT 1:20 PM (Merged)
  • 108,014 POSTS
It sounds like the park lock solenoid isn't releasing. It receives power from the brake light switch so first, make sure the brake lights are coming on. If they are not, chances are the switch is bad or out of adjustment.
DURANGOTROUBLE
2002 Dodge Durango Four Wheel Drive Automatic 175000 miles
the gear shift will not move out of park - help
  • 108,014 POSTS
There is a park lock solenoid designed to not allow the vehicle to shift from park unless your foot is on the brake. It is actuated through the brake light switch. So this may sound like a stupid question, but are your brake lights working? If they are not, check the brake light switch on the top of the brake pedal. If it is bad, it won't allow you to shift from park.
Let me know what you find.
RVLOVERS
2002 Dodge Durango V8 All Wheel Drive 85000 miles
I have a '02 Dodge Durango and just received a recall notice on it, however I can't get my car in for about a month. The recall is to correct a problem that keeps the vehicle from shifting out of park. We are experiencing some very cold weather and my car has started locking up in park. I have found that heat will eventually unlock the safety switch. My question is: Is there an emergency release on the car that I can utilize if the heat doesn't work? I promise to get the car in for the recall
  • 108,014 POSTS
Hi:
Stupid question. When it doesn't come out of park, are your brake lights working? The brake light switch allows the shifter to move from park when the brake is depressed. If the switch is cold and not moving, you won't get it out of park.
SHANNON RILEY
  • V8
  • 4WD
  • 48,000 MILES
Will not shift out of park
ROWTIEAR
  • 91 POSTS
There is an interlock switch located somewhere on or near the brake pedal.
This switch is there to ensure that you have your foot on the brake before you put the car in gear.
It sounds like the switch has either come unplugged or has malfuntioned.
Hope this helps!
GUY
  • 2003 DODGE DURANGO
  • V8
  • 51,000 MILES
2003 durango in cold weather 20's and lower sometimes shifter will not come out of park
Monday, November 18th, 2019 AT 1:21 PM (Merged)
  • 108,014 POSTS
Make sure the brake lights are working. You may have a sticking brake light switch. The switch that turns the brake lights on send power to the park lock solenoid to release it. Check that out the next time it happens.
ELIZAMARIA
  • 2001 DODGE DURANGO
  • V8
  • 4WD
  • 101,000 MILES
The car will start but will not come out of park
BMRFIXIT
  • 19,053 POSTS
check if you have brake light
BMRFIXIT
  • 19,053 POSTS
MINNESOTA13
Transmission problem
2001 Dodge Durango V8 Two Wheel Drive Automatic
cant get car into gear, automatic shifter seems to not be attached to transmission.
CARADIODOC
  • 33,699 POSTS
Suspect the metal rod has popped out of the lever on the left side of the transmission. You can see it from underneath. Check the rest of the linkage too to see if a joint is disconnected.
Caradiodoc
LROZ57
  • 1999 DODGE DURANGO
  • 110,000 MILES
I have a 1999 Durango SLT 4x4 that will not start in Park; nor does it lock in Park. It will start in reverse. Also, when you try to put it in park to turn off, it won't turn off. After you turn it off in reverse, you can put it in park & take key out; but it doesn't stay in park; it rolls. So I have to use emergency brake to keep it from rolling.
Monday, November 18th, 2019 AT 1:22 PM (Merged)
CARADIODOC
  • 33,699 POSTS
Adjust the shifter linkage or look for a loose bracket the linkage is attached to.
LROZ57
Thank you for the information! You sent me info on standard transmissions; I need the information for automatic transmissions. Sorry for the inconvenience. The shifter column is located with the steering wheel. Thank you!
