2003 Dodge Dakota Repair Question
Topics covered: Steering, Steering column, Wheel.
Asked on October 15, 2010
Wipers don't work
Steering problem
2003 Dodge Dakota 6 cyl Two Wheel Drive Manual 50000 miles
no power to fuses? Wanted to check wiper switch on steering column. Could not get lower cover off steering column covering switch. Tilt lever in the way. Couldn't get lever off. Any advice? thanks for any help.
Answer
Replied on October 15, 2010
before you can remove the tilt lever handle and then the shrouds, you must first remove the steering wheel with a puller. may want to test wiper relay before venturing into steering column.
